Imported site plan not appearing on elevations
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
bhetsua.tinoco
582 Aufrufe, 4 Antworten
I was following the Revit video courses, specifically "Work with CAD models from others inside Revit" and I was able to import the dwg site plan into revit's site sheet, however the video shows that on south elevation sheet i should be able to move the site plan 54' but on my south elevation is not showing the site plan. I tried View-->Visibility/Graphics-->Imported Categories where i should be able to locate the imported site plan with its layers but is not there either. Has anyone encounter this issue that can help?
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: bhetsua.tinoco
When you link the CAD file in, do not tick the box Current View only so that it shows in other views. And use Link, not Import.
Nachricht 3 von 5
Is it a 2D DWG?
What are you trying to do exactly?  A 2D DWG will just show as a bunch of linework stacked on top of each other on the same plane in an Elevation View.
Nachricht 4 von 5
I think I may have misread you. Are you saying you created a Toposurface from the Imported DWG and now you are trying to move the Toposurface down in Elevation? If so, turn on the Topography Category.
Nachricht 5 von 5
bhetsua.tinoco
als Antwort auf: ToanDN
@ToanDN  thanks this solved my issue. i was using the linkCAD but i had it in Current View Only.
