I have been trying to add materials to my imported .SAT and .3DM files. I understand that in order to achieve this, the user must go into the Object Styles and selected the imported name of the category and change the material.
Unfortunately, the imported category names are not showing up in my object styles. Is there any reason for this? I have attempted this with different categories and none of them portray the proper imported data.
Thank you for your help.
Hi @brobes05
Can you send us the file to test further? I can share a private folder if you'd like.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you very much for your reply!
I have attached the requisite file.
Kind Regards,
Erik
Thank you. I had a feeling this might be true.
The imported geometries are placed into the families categories in the project browser. Nevertheless, (as shown in the image), there does not seem to be an option to add materials.
Am I overlooking something?
Thank you.
Erik
Hi @brobes05
A similar case is in progress by the team that discusses Different behaviors between 2016 and 2017 when importing SAT in Revit
More details HERE
@ToanDN is right From 2017 version, SAT is not under the Imported category.
Take a look at this thread which discusses alternatives with FormIT
Can you upload your journal as well to test further?
Viveka CD
Yes, this is a similar case; however, the question is only partially resolved. I am able to import .SAT file categorically which is fine when I don't need to assign materials. As @ToanDN mentioned, if I import a .DWG it should be possible to change the material in object styles. I have not gotten this to work yet, but it should work.
Nonetheless, as importing a .DWG removes the category, I don't believe this query has been resolved as of yet. I appreciate all of your help!
