Imported OS background bigger than coordinates.....
32 REPLIES 32
Message 1 of 33
Billy_Burg
1153 Views, 32 Replies
Hi All.
I am not entirely sure that the 2 points below are connected but it does seem like a coincidence.
  • The linked DWG in our model has been scaled to +1000. This has been done to convert if from meters to millimeters since that is our default unit.
  • The problem I have is that when plotting various coordinates it is not showing the correct location. The distance is a lot closer and is the difference of about 1000. E.g. Onsite distance = 300m ---- model distance = 3000mm
  • We have since modelled pipework, structures etc.
Is there a way of scaling the coordinates to match the imported background?
Or a way for the coordinates to recognize this difference?
Labels (1)
32 REPLIES 32
Message 2 of 33
jay_colcombe
in reply to: Billy_Burg
Apart from changing The Project Units settings I cannot see another way of doing this!
I would simply bring the OS in at 1:1 using the import unit settings and change the project units to match if required!
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 33
Explain what you mean by "plotting various coordinates".
Message 4 of 33
Billy_Burg
in reply to: jay_colcombe
Re-importing the OS background at a 1:1 scale is certainly an option but our last one since we have modelled a lot already.
Message 5 of 33
Billy_Burg
For example if I go to the annotate tab > spot coordinate - to annotate areas where I want to show coordinates.
Message 6 of 33
jay_colcombe
What i was referring to was that the OS needs to match Revit  - a meter in Revit should be a Meter in the OS so the same scale!  (Even if the units are not the same mm or m)
To try and clarify as to prevent lots of posts
Have you drawing  everything in Revit at the right scale?  So 1mm = 1mm?
If so you can edit the Units of the Spot Coordinates to suit
Jay Colcombe
Message 7 of 33
What's the Coordinate Base of the Spot Coordinate?
Message 8 of 33
Billy_Burg
in reply to: barthbradley
Survey point.
Message 9 of 33
Survey Point Marker and Survey Point ORIGIN can be at two different locations.  Perhaps you unclipped and moved the Marker away from the Origin.
Message 10 of 33
Billy_Burg
Hopefully this gives a bit more clarity. The image shows the edge of a walkway. The 2 coordinates shown on the right should not be near each other. Coordinate N50.357 E-4.834 should be on the opposite corner bottom left. The length of this distance in the model is 10000mm but the distance between the coordinates is 0.1. Bit confused!Edge of pontoon.png
Message 11 of 33
Post the file.
BTW: how far from the Project Internal Origin are your elements?
Message 12 of 33
jay_colcombe
in this model i know that i am using Millimetres as this is the Base Units for this Template so it is recording 800mm for the Pile Cap which is 800mm in width so i know this is correct but my Spot Coordinates (for the Survey Point) are set to Metres - does this happen with your model?
Jay Colcombe
Message 13 of 33
Billy_Burg
The OS background we use is in a DWG format which is linked into the RVT model.
Message 14 of 33
Billy_Burg
Ok. So units used in our template for length is mm under the common discipline. This is why it shows 9000mm on the side of the snapshot shared before which is correct. No it doesn't show that because (I think) I have set the spot coordinate property to mm.
Message 15 of 33
Spot Coordinates report accurately on my end.
Moved Survey Point Marker to Survey Point Origin:
Message 16 of 33
Billy_Burg
Hopefully this also explains. Not sure what you mean @barthbradley example.png
Message 17 of 33
Billy_Burg
Another example of where the coordinates are in real world but not the same in our modelgrid reference finder.png.
  • Red = N50.357600 E-4.832417
  • Green= N50.357417 E-4.834033
  • Orange = N50.357400 E-4.834200
Message 18 of 33
jay_colcombe
You need to reset your coordinates and start again as there is some incorrect information being shared between models and links.
Jay Colcombe
Message 19 of 33
Billy_Burg
One last ditch attempt at understanding what's going on with my model! Attached is a RVT with an OS Background linked into it (not changed). The walkway showing 2 spot coordinates are correct for setting out the walkway. This is where I want these 2 points to be. My problem is that now the model is too small for when I do dimensions and model elements in. Everything is too big for example when I draw a pipe or show a dimension. Have I lost the plot?
*****Apologies I gave the wrong coordinate unit before. I got confused myself and was using decimals instead of easting and northings. The easting and northing coordinates shown in the attached model are correct for what I want at these points on the walkway.
Message 20 of 33
Coordinates are dead on ballz accurate using the Specify Coordinates at Point method.
Help | Specify Coordinates Before Linking Site Data | Autodesk
Note: this screenshot is using your first attachments.
Forma Design Contest
Technology Administrators
