Imported geometry from rhino in Revit not showing in some views
3 ANTWORTEN 3
Nachricht 1 von 4
g_thong
238 Aufrufe, 3 Antworten
I have created a balustrade geometry in rhino that I have imported as a dwg into a generic model family in Revit. In the family there is a LHS balustrade and a RHS balustrade. When loaded in, the LHS balustrade appears correctly, but the RHS does not show up in my main section, but doesn't show in some others. If I import the same geometry as a .sat file, it shows up in this section, but doesn't cut. Both the balustrades are a "closed polysurface" in rhino. Is there anything else I can try/other format that might work?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: g_thong
Why don't you import the 3dm directly?
Nachricht 3 von 4
g_thong
als Antwort auf: ToanDN
Thanks for the suggestion - when I import it in .3dm it shows in the section but no longer cuts in plan view
Nachricht 4 von 4
syman2000
Post up the Rhino file.
