why i inserted this type of family it doesnt even show in project, i can select it and edit on it in edit family but when it come to the project i cant see it, i already checked VG and did many things but i dont know wheres the problem?!
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
- VG > Imported categories > turn on Imports in Families
- Set view the Fine
- If the above don't work, share the family
Here's a good resource to keep handy and reference when you can't find stuff in the view...
Missing Something in a Revit View? 33 Steps to Find Stuff | Ideate Inc
Check and see in the family if the object is far away below the origin point. As well check and see if the object in the family is checked off for visibility.
Nothing worked, i already uplode the family
The family is set to only show up as fine. If you want to show up all the time, you have to edit the family, click on visibility graphics and check on course and medium.
