I'm importing a DWG and it's not visible (Using Revit 2018.2).
Starting off from a fresh new project, based on our template that never displayed this problem before. Imported it in current view only, in a floor plan. It's definitely there, because I can select it and while hovering the move tool above it, the tool snaps on lines and corners. But everything is white on a white background. Also, while inside the import CAD dialog box, when I select this DWG, a preview is visible. The preview has a black background with colored lines for the design.
I tried every option in the import cad dialog box (invert, preserving or b&w colors; specifying layers (specifying some or just all), setting import units. I checked my view range to make sure it should be visible. Tried every setting in Visibility Graphics ( > Imported Categories).
Like I said, it's definitely there, because I can move it around and snap tools on it, it's just not visible. Because it might be a more challenging problem to solve, so I'm linking the file for those interested in solving the problem. Please be discrete and do not share outside this forum, or even thread: Link to invisible DWG
Thinking this is definitely a problem that started out with the settings our client, an architect, saved his DWG with. But I also prefer solving problems on our end. A tool like Revit should be able to solve this problem.
