Imported dwg lines not showing
1 ANTWORT 1
Nachricht 1 von 2
bvanallen
209 Aufrufe, 1 Antwort
Got an odd one I need help with.
I have an imported dwg withing Revit 22, that does not show everything withing the dwg. To be clear, the dwg itself IS showing up. It is on the right level, lined up, not clipped, etc. I CAN see text within the dwg, but not the lines or arcs. And before anyone asks, yes it is set to visible within the imported links visibility graphics. I have also tried to override the layer to be solid black with a lineweight of 10. It still does not show up on my screen. EXCEPT for when I select the dwg and highlight it, then I can see the lines & arch. Attached are two jpegs of what it looks like.
I've had another person in my office pull up my model, and it DOES show up on their screen, even when not highlighted. We have identical machines, on Windows 10 pro, with an AMD FirePro 7100 craphics card (I double checked and all our machine specs exceed the minimum requirements). There are not available updates, for our machines or on the desktop app. I have not overriden any settings in Revit 22, that I know of, nor do I have a template set to my current ceiling plan view.
So, does anyone have any ideas what might could be causing this?
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: bvanallen
Wireframe View?
