11:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I am trying to figure out why revit's contour line doesn't match up with the imported points... I cant find a forum addressing this.
I made smooth contour lines in Rhino with assigned elevations and then exported as a DWG. It looks like Revit is simplifying my lines by skipping tight corners, and I am unable to force the contour line to match the points - the contour line just won't move where i want it to. Why could this be?
What other methods do you use to import topography into Revit for free?
Thank you.
Link copied
