In a Revit project we have sections cut through a generic family created using imported AutoCAD files containing solid models of pipes and walls.
When we were working in Revit 2014 we were able to shut off demo layers in section views. Now that we have upgraded to Revit 2018 (and advanced the design substantially) we've discovered that our sections are not displaying correctly.
We can shut demo layers off in plan views but in sections the demo'd pipes can not be turned off.
Does anyone have a solution to this problem?
Not sure what the issue is; Visibility/Graphics or Phasing, but it sounds like some setting is different. Do you have the correct Phase Filter in the view? Is the VG settings for the Imported Categories the same as before? I seen such things happen before, because Temporary view VG settings weren't applied permanently to the view.
@barryknittle1623 wrote:
We didn't know that phasing could control an Autocad demo layer nested inside a family. We'll check out if this works for us.
Barry
It can't. But maybe maybe another element is out-of-phase and obscuring import. Is Import in Background or Foreground?
Did you go to the VG > Import category > and expand the Layer tree under Import in Families?
The generic template was used to create a family. The AutoCAD file containing the 3D solids was imported into this family. The family was saved and inserted into the Revit Project.
Can you use Tab and select the Cad import, then hide layers?
Try creating a new Revit test project. Load the family containing the Cad. Cut a section, try to hide the Cad objects. Does it work?
If not, please post the "test" .rvt and .rfa here.
OK--good call on going "all Revit". It will save you a lot of time and frustration in the end.
You would need to expand the Imports in Families to see those layers. Still, create them in Revit is preferred.
