Hey all,
I'm new to Revit and one of our clients has a very big BIM file of there planned building.
We are doing the interior in a conceptual fase right now and they would like us to offer them outside perimeters.
So they can see where there will be clashes with HVAC and other contractors.
I found online that i can export my interior shapes out of Sketchup as a 3d cad file.
After that i opened a new conceptual mass file and imported the 3d cad file.
All these steps looked ok.
But now i have opened the Revit file of my client and i want to import the conceptual mass file in there and nothing seems to work.
I went in the Project Browser and selected the floor i needed to import the mass to.
But when i do it with PLACE MASS i don't see my interior elements.
Can somebody help me or offer me some more insight please.
This is not a program that you can learn by yourself, although my company seems to think i can ;).
Kind regards.
Hope to hear from one of you.
Michiel Van Dercruyssen
Your workflow is unclear to me.
the 2 ways we use to insert a SKP file into Revit are:
Insert Tab=>Import CAD=>Change file type to SKP and the select and load the SKP File. If this doesn't work, we bring the SKP into AutoCAD via "ImportSKP" add-in, and save as a DWG. Then back in Revit we load SKP-DWG via Insert Tab=>Import CAD=>Change file type to DWG and select and load the SKP-DWG.
I made a mass family of my sketch up file.
But now i want to import it on the second floor of my revit model.
How do i select the right level and how do i import my file right.
When i import it know, i don't see anything.
Is the Mass Category Turned on in the View?
Is "Show Mass by View Settings" activated under the Mass/Site Tab?
Hi @Anonymous,
Welcome to the forum and thank you for reaching out to the forum. Have you had a chance to look over the suggestions provided by @barthbradley?
Do you have any questions about it, let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps makes the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you. ![]()
We're delighted to have you as part of the Autodesk community and hope you'll come back often to benefit from our Forums, Training Videos, User Groups and other resources.
