Import Rhino to Revit using Shared Coordinates
1 ANTWORT 1
Nachricht 1 von 2
haochen.yangCNKF3
722 Aufrufe, 1 Antwort
Hey,
Our team is working on a streamlined workflow between Revit and Rhino. We want a base point to align different Revit models and Rhino models together and we decided to use the shared coordinates as the base. But when importing Rhino to Revit, Revit seems not able to use the world coordinates in Rhino as the shared coordinates. Is there a way to make Revit do this?
This is the notification in Revit I kept getting.
Haochen
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: haochen.yangCNKF3
- Link 3DM in center to center
- Move it to align with your model (if you have a brand new blank Revit file then this step is not needed)
- Acquire Coordinates
