I'm working with architectural CAD files that have multiple floor plans stacked on top of each other, which are controlled by layer states. If I LINK the file into Revit, it will automatically apply a VG filter based upon the last saved state of the drawing, (which matches whatever AC Layer State it was saved as). The autocad file has 3-4 layer states per floor, so multiple floor buildings are even worse. Is there a way to automatically create separate VG filters by importing the layer states from AutoCAD? Manually making the VG states for each view would be a huge time constraint.
If I try to unload and reload the dwg file, it will either revert to the previous version, or just display all the lines as "ON".
Is importuning a new COPY of the drawing the only way for AutoCAD to automatically recognize the "saved" layer state (if I save it in a new state each time?)
@sfulnerQ57QF wrote:If I import the file into Revit,
Stop, don't do this. Link it instead. It's not going to help with your question but it will prevent headaches later on.
That was a mistype. I am linking the file (as you noted, it doesn't help with the headache, but reduces additional ones).
Make sure to check the box below when reload.
@ToanDN That sort of worked, and I feel it's a workaround. Here's what I mean.
The way the architect has chosen to set up the drawings in CAD, they stack everything in model space, then x-reference the model to separate files for each paper space print job.
If I link the secondary file for each floor, with the check box as indicated, it works as designed/intended, deleting all other layers, and I can make a VG viewport for that if desired.
However, if I save the "central" CAD model file in the open view (with it's layer state), the first time I link it shows the saved layers as intended. If I link (The same) model a second time to another floor, even with that box checked, it seems to forget I did that, and links every single layer, with all of them on. Obviously I get the error of "this may create duplicate instances" of the link, but I would still expect it to work as intended. The main reason I want to use the central file than the separate files, is early on, they don't have the separate xreference files made, so I only have the central model available until late in the project.
There is another workaround:
