Hi, if I have a point cloud and I want every local user to load it, just from his local files bcz PC size is very large, can this happen ?
I don't recommend this. Typically I would have one or two users have access to the point cloud. Let them be in charge of taking care of the point cloud coordination. As well I recommend to have point cloud as separate model from your main central model. That way the user incharge will access that point cloud model and the central model will link directly into the pointcloud model.
Also is the point cloud split into smaller section or it comes in as one piece? If it is smaller section, you can control what point cloud gets loaded and what to unload. This will help you deal with the massive point cloud and you don't needed to load everything in one go.
