Import multiple shared parameters to multiple families using Dynamo
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
gustavtornblom
260 Aufrufe, 2 Antworten
Hi! Im trying to find a way to import multiple shared parameters to multiple families using Dynamo. Its a drag doing this manually since I have many families and 10 parameters.
The ideal solution would be a dynamo solution where I point to the directory of the families. If that isnt possible it would be nice with a dyn that would import them all into the open family in Revit.
Anybody who wants to give me a hint? :leicht_lächelndes_Gesicht:
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
Tom_Kunsman
als Antwort auf: gustavtornblom
You might want to try the Dynamo forums for this question. You can do a search there for what you are looking to do. Just be advised that users on that forum will expect some sort of work for you to share
Dynamo (dynamobim.com)
Nachricht 3 von 3
gustavtornblom
Thanks. I just found it, I wondered why I found few posts on dynamo
