Import Geometry from Civil3D to Revit
Hi everyone.
I have DWG file created by civil3d that contain some surfaces (for floors) and extrusion (for walls and stairs).
i try to import the file to revit and everything works fine (in 3D).
***BUT:***
Working on 2D create some problem , when i try to create some section it does work fine.
for example : Although the far clipping is 2 cm the section show all the view range from start to end.
as you can see i create the section in the middle of the building.
what im trying to do is to create some element/mass/anything that illustrate the civil 3D file.
hope i was clear enough.
i added the DWG file.
hope you can help.
