Hello!
I export a Revit model into Autocad but now, my doors and furniture are in the same layers as Revit. When I export my Cad into PDF, my doors and furniture render in color even with BYLAYERS in properties. Is this something I can do on Autocad?
Thanks!
It is a well known issue in the community, modifying DWG/DXF Export setup is quite a workaround, and hard to know for sure how it will works. Same with PDF files. Take a look to this post:
What plotstyle are you using in AutoCAD?
