HI All,
I am modeling a crane on a Revit Family template for metric furniture, and I want to provide stairs till the top of the crane and some handrails on the top beam.
I though that the quickest way to do so would be creating them on a project and export it to a family, but I couldn't manage to do it.
Any idea about how to do it or work a solution around without modeling the stair step by step??
Thanks for your help.
Gelöst! Gehe zur Lösung
Gelöst von Sahay_R. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Export to DWG also works.
Another solution - if it's a ladder that you can work with, then create the ladder as a line based generic model family, and nest it into the crane family.
Thanks for your help, both worked very well. I used the dwg option cause it produced a lighter file and it didn't remove the balusters from the handrails. ;D
DWGs have layers that can be assigned with different materials and visibility. SAT is a monolithic solid if you need everything as one piece. Handrails should export to SAT just fine, when doubt, you can change the export option to ACIS Solid instead of polymesh (though both works when I tested it).
