Import FormIt into Revit "Disable Updater" Problem
5 ANTWORTEN 5
Nachricht 1 von 6
408 Aufrufe, 5 Antworten
I converted a "SketchUp" file to a "FormIt" file to a "AXM" file and I'm trying to make a "RVT" file but I ran into a problem when I was importing it. I put in the screencast not sure how to solve this issue.
5 ANTWORTEN 5
Nachricht 2 von 6
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, you can try to check it HERE and HERE. thanks
Nachricht 3 von 6
Hello nbaker13,
What do you want to do? DO you want to convert Sketchup file to REVIT file and want to keep all the materials intact?
CHeers!!
Prattusha
Nachricht 4 von 6
yes thats what I'd like to do
Nachricht 5 von 6
Sahay_R
Have you just tried to import / link your Sketchup file?
Insert >> Links CAD / Import CAD
And you will find Sketchup in the list of acceptable filetypes.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 6 von 6
Hello nbaker13,
 You can import the sketchup file in the REVIT using the insert tab -> Link CAD-> File types option as sketchup. But you won't be able to get the materials right. It will be imported with just 1 layer. It's better to do the modelling in REVIT.
Prattusha.
