Import DWG without moving and rotating to RVT with coordinates?
Still having problems with the basics of importing / referencing / coordinates ...
I tried with a simple example:
- I have a DWG, with a rectangle, rotated 33°, left lower coordinates 20/30, 100 x 15 meters. This is the outline of my "house".
- In Revit, I draw a rectangle from approx. 0,0, 100 x 15 meters, no rotation. This is the Revit-outline.
- Then I used the "Shared reference Point" tools: exported the data from Civil, imported it to Revit.
- Now I check my rectangle in Revit - perfect: left lower coordinates at 20/30, rotated 33°, right upper coordinates haves the same values as the DWG in Civil
So far, so good.
But ...
How to import (or reference) the DWG to RVT? I thought that now both files have the same "system" and the imported DWG is exactly on the same position as RVT - but I tried all comands and settings for import (reference), but either
- the direction (orientation) of DWG is correct, but the position is wrong or
- both direction and position of DWG is wrong.
Should it be possible to import it without modifications?
Or is it unavoidable?
Thanks and regards
