Import DWG survey file to create toposurface in Revit
6 ANTWORTEN 6
Nachricht 1 von 7
569 Aufrufe, 6 Antworten
Hi everybody
i have managed to get a lot of point withdrawen from a landsurvey plan.
but everytime i try to load them into Revit i get this error? can you tell what the problem is?
i embedded my points file. (also tried it as a *.csv file - same result)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Can you send the CSV?
Nachricht 3 von 7
als Antwort auf: ToanDN
Hi ToanDN
Here you go. :leicht_lächelndes_Gesicht:
Nachricht 4 von 7
And one where each part has their own column.
Nachricht 5 von 7
Should it be different than the ones i sent?
Nachricht 6 von 7
It did not work.  Attached is a CSV that works.  Open them in Excel and you can see the format between the two are totally different.
Nachricht 7 von 7
Yeah i see.
Thank you for your time :leicht_lächelndes_Gesicht:
ill try to figure it out.
