I recently imported a cad file.
First off, how do I delete the imports I can't see, this may be causing the issue.
In many views, when I start to zoom in, the zoom just starts to move me laterally for some reason.
Also, in 3d, when I go to hidden line, or shaded, it keeps the view in wireframe.
Gelöst! Gehe zur Lösung
Gelöst von mauricio_mssf. Gehe zur Lösung
You can zoom in on one of the project views, and select the entire project, and then on the modify tab click on filter and search for the .dwg file you want, uncheck all others, leave only the file you want to select, ok, and then delete
it seems that the dwg is too small or too far from the rest of the project, you need to check why it is not seeing, if it is the insertion point or scale, or even the Autocad georeferencing / coordinates is correct com os do Revit.
There is an old post that talks about this with solutions with a Add-in, dynamo, etc, you can also try it.
https://forums.autodesk.com/t5/revit-architecture-forum/deleting-imported-categories/td-p/1455947
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
