Import CAD sketch into vertial Work Plane (that is set on a wall face)
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
T2ioTD
403 Aufrufe, 5 Antworten
I am trying to make decorations for an external wall (something like checkerboards with an arch etc) and I have drawn the sketch in Autocad starting from the origin, and drawn vertically. I prepared my work plane in Revit, but when I'm inserting the file it always goes behind the wall, and no matter how many times I try to move the imported sketch to the plane itself it will move only within the insertion vertical plane.
Can you help?
5 ANTWORTEN 5
Nachricht 2 von 6
anze.kumar
als Antwort auf: T2ioTD
Maybe try to place a Section in the floor plane directly on the surface of the wall and insert the CAD in the section view.
Nachricht 3 von 6
kostask_oionei
You can create a detail item family and import the autocad file. Then import the family in the project.
If you want to view the lineworks in 3d also then create a generic model family.
If you want to put the lineworks in a face or workplane then create a face based generic model family. In this case you don't have to change work plane.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 4 von 6
handjonathan
Hi @T2ioTD
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @kostask_oionei @anze.kumar  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 5 von 6
ennujozlagam
have you try to load in a wall base family and load in to your project and see if helps. thanks
Nachricht 6 von 6
T2ioTD
als Antwort auf: kostask_oionei
Thanks for all the answers. I went on and adopted the solution of using a face based family, and it worked.
