Import Cad Into Sections
PhilvK
Advisor Advisor
Message 1 of 9
PhilvK
Is there a different process for inserting (importing) a cad drawing into a section? I can do it OK with plans, but when I try to inset into a section I get the message that “None of the created elements are visible…” in the section view. The import is listed in Visibility Graphics, but I cannot find it anywhere in the model.
Replies (8)
Message 2 of 9
When insert or link a CAD section/ elevation drawing in a Revit section/elevation view, check the box "Visible in current View only".
Message 3 of 9
PhilvK
That works up until the point I complete the insert. I can drag it into place, but after I complete the insert it does not appear in the view unless I set the view to wireframe. I can then see it beyond the plane of view, but can’t bring it forward, and I don’t see it in any other views.
Message 4 of 9
Switch the View to Wireframe, select the CAD drawing and change Draw layer to Foreground.  When done, switch the view back to Hidden.
Message 5 of 9
PhilvK
Genius! Thank you!!
Message 6 of 9
dave_perkin
cant get this solution to work with Revit LT? -
Message 7 of 9
That did not work for me in RVT 2016. I did the following:
  • Import CAD file into revit plan view
  • explode it
  • Delete raster images
  • Create detail group
  • Cut and paste into section
Message 8 of 9
PhilvK
Thanks again for this answer, 6 years later! I had forgotten it.
Message 9 of 9
leviN2LHE
Glad I'm not the only one haha
