When I try to insert materials from the Enscape library, the IMPORT button is missing as the material editor window is too big for my screen. I have tried hiding my taskbar in windows but that didn’t work. If someone can help me out that would be great.
Thank you
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
https://forum.enscape3d.com/index.php?thread/22713-problem-whith-the-import-button-materiales/
To increase resolution, go to your display settings and set the display resolution
Thank you. My current resolution is set 1920 x 1080 which I believe is the recommended for enscape?
My resolution is also set to the highest it can’t go larger than 1920 x 1080
Usually 1920x1080 should work. Do you have zoom in screen or text set to 150%? Try to update the graphic card. Typically this will dictate what gets display on screen.
