Import 3D CAD onto Revit Elevation
 See video for question much better than text.
You can try exporting out as an IFC file from CAD...else build it in Revit using a curtain wall.  May require two of them if you don't  want separations between the mullions.
I am not able to export from AutoCAD as .ifc file.
You can't unless you modeled it in a vertical such as AutoCAD Architecture.
Wblock the part you want show to a new DWG file.  Link it in Revit, or link it in an in place family as a generic model.  Move it to align with your Revit model.
