imperial to metric
2 ANTWORTEN 2
Nachricht 1 von 3
737 Aufrufe, 2 Antworten
imperial to metric
Hello!
If I want to change all units from metric to imperial, do I have to change every single component (It will take a lot of time and effort since there are a lot of components within certain disciplines including  Common, Structural, HVAC, Electrical, line weights, Piping, and Energy that have to be changed), and I need to do this every time when I open new Revit file.
Or, is there any simple way to do it?
2 ANTWORTEN 2
Nachricht 2 von 3
Alisder.Brown
als Antwort auf: Anonymous
Hey
Are you using company specific Templates or existing projects? If so you will need to change each Project file. ("Manage" tab > "Project Units")
There is not a "Switch from Metric to Imperial" button unfortunately. The units are project specific, so the best option is to spend 15 minutes changing your template file (or multiple template files) and then replace your libaries with the imperial ones from here: https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
If you are using the default Revit templates, simply download and install the Imperial content (Templates, Family templates and Familys) and use theese as your template. Doing this, any new project will default to Imperial settings
Hope this helps
Alisder Brown
Senior BIM Coordinator
Scotland, UK
Nachricht 3 von 3
planner_matlabi
Hi
Use templates for the imperial
Download Template Based on Revit version
OR
Revit Install but Online !!
In Step Install , Step 3 , in Contact Library , open Menu and Mark imperial
