Imbed walls
3 ANTWORTEN 3
Nachricht 1 von 4
glkirk
237 Aufrufe, 3 Antworten
Imbed walls
Good Morning,
Could someone help me how to "Imbed " walls so that this corner condition does not happen?
This project uses a continuous cmu foundation. It seems easier to me to try to run my stud with brick down to footing.
But I usually have problems.
I guess I use the cut tool but have had no luck.
Could someone help me with this?
Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: glkirk
Post your RVT
Nachricht 3 von 4
So your stud walls sitting on the CMU but the finish extend to cover the CMU? If so, model the walls so the brick face proud of the CMU face, then join CMU to the stud wall (in that order), and then you will have what you need.
Nachricht 4 von 4
glkirk
als Antwort auf: ToanDN
I have not had luck with this procedure yet, I will keep trying. Thank you!
