Hi, all of my Revit LT 2022 files are now showing images as just black boxes. I was using the images to display logos in my title block and they previously worked fine. I also tried starting a new file and loading different images just to see if I could isolate the problem but was unsuccessful. My graphic card drivers (NVIDIA GeForce GTX 1660 Ti) are up to date and the issue persists for JPG, BMP, TIF, and PNG image formats. I appreciate any help, thanks!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Just installed the latest update and images are working again! A program file must've become corrupted and then the update replaced or repaired it. Thanks for the suggestion!
@bmoran7KNB6 wrote:Just installed the latest update and images are working again! A program file must've become corrupted and then the update replaced or repaired it. Thanks for the suggestion!
Probably some Windows Update that upset Revit. That's my guess. Glad to hear Autodesk is on top of it.
