I'm trying to place images of lighting tags in a lighting schedule. At this point, I believe the best way to do this is to convert these tags to jpegs and place them that way. When I restore these images to their "original size" in the column they come in much bigger than the original image when I saved it at 300 dpi. Is this because revit considers the original size to be 72 dpi? Any help with this issue is greatly appreciated.
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
The image in a schedule depends on the the columns size they are placed in.
Some advice regarding schedule images. Make them all the same size. Keep them small.
When I have a lot of images I try to make them 300x300 with 72dpi
Louis
Please mention Revit version, especially when uploading Revit files.
Thanks for the response. I guess my question is associated with the "original size" that you can specficy for images when the column width is driven by that. If an image is X pixels wide does this play out at 72 dpi or is there a way to adjust the default DPI for the original image size?
Mike
Forget about the DPI and pick the right dimensions for the images. Images in a schedule need not to be larger than 300 pixels x300 pixels.
Hi!
Is it possible to create a schedule or material takeoff that can show the material's render appearance when a new material is created or an existing material is edited? Additionally can this linked image be a parameter that is affiliated to a finish tag?
