Image in front of filled region in title block
4 ANTWORTEN 4
Nachricht 1 von 5
PieterL_TM
272 Aufrufe, 4 Antworten
Is there a way to have a raster image in front of a filled region in a title block.
It works in the family, but not once I load it into a project.
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
vitorbortoncello
als Antwort auf: PieterL_TM
Try placing the image last, after the filled region, to see if Revit prioritizes its display or create separate families for the filled region and image, and load them in the desired order.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 5
Nachricht 4 von 5
handjonathan
Hi @PieterL_TM
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 5 von 5
PieterL_TM
als Antwort auf: handjonathan
I'm sorry for saying this, but these kinds of comments are super annoying. I'm reading the suggestions, if anything solves my issue, I will accept this as the answer. If more info is asked, I will provide it.
