I rendered a plan and a perspective view with the Illuminance Cloud rendering tool.
I followed this tutorial: Illuminance Rendering Tutorial
The settings are:
Date: 21 March 2017 (Spring Equinox)
Time 12:00
Sky model: CIE Overcast Sky
DNI:800 W/m2
DHI:125 W/m2
Units: Lux
Legend: Automatic
The render of a perspective view appears blue (dark). However, the same area appears yellow(bright) on the plan rendering for the same settings.
This is wrong as the lighting is different in each view.
The odd thing is that I don't have any artificial lights in the scene, therefore the perspective view correctly appears dark. That means that there is something wrong with the plan view. What can I do to fix it?
I have attached the 2 renderings.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
hope the above helps
@Anonymous
Good to see that the issue has been resolved... it would be nice if u could upload and share the new renderings
The solution to this was actually the way that the camera is set in Revit.
Initially I set up the camera by :Cube > Context menu > Orient to view > Floor Plan.
This was wrong as it technically creates a section box and illuminance renders do not work with a section box. This is why I got uniform radiation in the plan rendering. It was actually rendering the plan as there was no ceiling.
The correct way to set the camera was to create a orthographic camera, and then click the Top of the cube and create the plan cut using the eye elevation option on the properties panel, under camera settings.
This is what the final image should look like.
To be honest, still this isn't accurate but it as close as I could get to the actual distribution of light.
@Anonymous
Thanks for the feedback...it will help many others I'm sure...especially that one rarely finds questions and solutions on LAR on this forum ![]()
Cheers
