IFC4 LinkIFC - IfcAdvancedBrep not visible
2 ANTWORTEN 2
Nachricht 1 von 3
klqa_test
511 Aufrufe, 2 Antworten
Hello, I was trying to understand and working on a IFC4 export feature from my application.
I've been referring to examples in https://standards.buildingsmart.org/IFC/RELEASE/IFC4_1/FINAL/HTML/schema/ifcgeometricmodelresource/l... but the examples are not showing when I link IFC in Revit2020.
I tried with a simple box and a flat surface, and it shows correct in BimVision.
But it does not show when I linkIFC in Revit2020.
IFC test file attached.
Is there anywhere that I can find more Revit working IfcAdvancedBrep examples that are using IFCBSPLINECURVEWITHKNOTS and IFCRATIONALBSPLINESURFACEWITHKNOTS ?
/zac
2 ANTWORTEN 2
Nachricht 2 von 3
Rafal.Gaweda
als Antwort auf: klqa_test
Hi @klqa_test
Here You can find Autodesk IFC manual https://damassets.autodesk.net/content/dam/autodesk/draftr/2528/180213_IFC_Handbuch.pdf
Please check it.
Rafal Gaweda
Nachricht 3 von 3
mikako_harada
Hi Klqa,
Not visible part, could it be the same reason as your previous issues, i.e., small element?
https://forums.autodesk.com/t5/revit-architecture-forum/problem-linking-ifc-extrusions-into-revit-20...
Do you see a warning when you open?  If not, we may add the sample to the enhancement wish in another case.
https://forums.autodesk.com/t5/revit-architecture-forum/link-ifc2x3-supported-ifc-solid-model-geomet...
Mikako Harada
Developer Technical Services
