Does Revit support IFC textures render appearance such as a jpg, or png?
Or, have the ability to transfer jpg/png information/name?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
The request to export material textures to IFC has been on our wishlist.
I've posted the Idea HERE on the Revit Ideas forum. Please vote for this idea to get considered. Your opinions count and feel free to comment further about your workflow and why you need this.
The supported classes in the Revit IFC export can be found in the Revit help, under Supported IFC classes.
I see if I have more input from the dedicated team.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thank you so much for the reply, and I get that Revit does not export textures.
Does Revit also Not have the ability to import textures?
@Anonymous
You are welcome!
Yes, this feature is currently not supported. I will update if anything changes.
Viveka CD
