I have a question about material change to an IFC file in Revit.
I imported an IFC file into Revit 2019 and am trying to apply materials.
However, the model always shows up grey when rendered.
Is there a way to change the material of things in an IFC model in Revit?
Thank you.
You mean you OPENED an IFC? It sounds like the Material the IFC Element is using has no Appearance Asset/Properties. What Material is it using? You can change it too. Edit IFC Element and assign a different Material from your Project.
...could also be as simple as changing the Phase Filter to "Show Complete".
