Is there a way to export Revit built in Category to IFC without having to tick "Export Revit Property sets" as this will export all the Revit parameters and I want to export Category only.
I have tried using IFC Mapping, but it did not work.
I found this blog article that guides through a similar process.
https://bimcorner.com/exporting-ifc-from-revit-part-3-user-defined-properties/
Doesn't the Category already get exported into the Pset_ProductRequirements?
Even if the "Export Revit Property Sets" is off.
Exporting the Category value to a custom PSet might not be possible, as it's not really a Parameter but a property of a element.
You could try and include Type = use I/T instead of only I?
Also is "Other.Category" a Revit parameter?
Format is:
<Property name in IFC> <Data Type> <(optional), Revit parameter if name is different from IFC property name>
