I have an architectural model where I link models from other disciplines like instalations and construction. This models are all in the IFC format. I don't want to duble elements from this models to my architectural one but there are some problems with this approach. For example if I want structural columns to by filled with reinforced concrete hatch, I nedd to insert this hatch to revit catche file and then i can override it in my architectural model. But when I get an updated ifc file, I have to repeate all procedure from the beginning. Problem occures also when I want to dimension some structural elements. After updeating structural file, revit remove dimension lines.
Is there any possibility to update ifc file on the same principle like in Navisworks, where if you just change linked file to new one, and it has the same name, it treat it as the same file?
