IFC import misplaces rooms
2 ANTWORTEN 2
Nachricht 1 von 3
Jouni_Malinen
244 Aufrufe, 2 Antworten
I need to convert a Revit model first to IFC and then back to Revit. Otherwise, everything goes well, but the rooms do not stay within the walls. What can I do? Attached is the original Revit model (Project1.rvt) and the imported one (Project1_fromIFC.rvt) which show what the problem is. Using Revit 2023.1.2
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Jouni_Malinen
I'm not able to replicate on my end using the in-session setup.  Can you share your setup settings?
Nachricht 3 von 3
Jouni_Malinen
als Antwort auf: barthbradley
Hey,
and thanks for replying me. I'm using in-session setup when exporting IFC without any modifications.
The problem has existed in all versions since at least 2018 and continues in version 2024.
If I link the IFC the rooms are in right place but they are changed to generic models.
