I have a very peculiar issue.
One of our consultants uses Planca Nova and provides us with the IFC file.
When I import this IFC into my revit file, the north is off. It appears that the IFC export from Planca Nova exports with True North.
We also use Naviswork to observe and issue resolves to Clashes.
So in Naviswork if I import all the part models (Arch, HVAC, Structure) they all lineup just fine.
The issue arises when I mix the file types, I mean I import a RVT file and then try the IFC from PlancaNova, the elevation is off. the IFC lies way below.
So either way there seems to be something I am missing here.. I really hope someone here can help me narrow down the issue.
here is the link to the same issue I posted to Navisworks Forum https://forums.autodesk.com/t5/navisworks-forum/ifc-import-and-rvt-import-dont-match-in-height/td-p/...
Cheers, K
Kunal Tuljaram Gaidhankar
