IFC-GUID delete parameter
Hello everybody,
i have a problem with the IFC-GUID parameter. I did an IFC export and select the option to add the "IFCSITE hight" and the "IFC-GUID" parameters toe the elements. Now I need to delete this parameters. I did again an IFC Export without this options, but the parameters still exists.
In the project parameters I can´t see this parameters, they are just visible in the property of each element.
I have another old shared parameter I want to delete, too. But here is the same problem as the IFC parameters. This shared parameter is not visible in the project parameters and just visible in the element properties. But this paramter is not part of the family. I can just export the shared parameter to a new file.
Maybe both problems have the same solution.
I couldn´t find a node in Dynamo that helps me. Maybe there is a dynamo option?
I hope somebody can help me.
Thank you very much!!!
dbernausLLGWU
Observer
Observer
Here is a simple script that will erase the ifcGUID Parameter for the selected category.
