IFC file linked into Revit, Geometry being lost
2 ANTWORTEN 2
Nachricht 1 von 3
jcurryX6UBB
268 Aufrufe, 2 Antworten
Hi
I am having issues when linking an IFC file into Revit. Openings in the beams are being lost when it loads into Revit. The openings are present in the IFC file itself but are being lost when linked to Revit. The IFC file is an export from Tekla. It is not happening for every beam however it is happening to approximately 30% of the beams in the model. Any help to resolve the issue is greatly appreciated. Thanks
Regards
John
2 ANTWORTEN 2
Nachricht 2 von 3
LFBIMMAN
als Antwort auf: jcurryX6UBB
Hi john , stumbled across your post the company I work for uses a different architectural software called archicad and we have seen similar problems if the IFC classification settings are wrong or missing, so they are not being picked up by revit..... just a place to check I suppose.
Luke
Nachricht 3 von 3
jcurryX6UBB
als Antwort auf: LFBIMMAN
Hi Luke,
Thanks for your response, unfortunately it did not resolve the issue. For the time being our subcontractors are working to the Cell set out drawings and the issue is not as urgent to resolve. Thanks for your help.
John
