Hi everyone,
So one of my colleagues uses Archicad and they designed a topography model in it, and they exported a IFC file.
However the geometric lines are not correct, its all triangular form. So basically the contour lines are not correct, so is there any way to fix that? I've attached a image below to help understand my circumstance.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Sounds like you are referring to this setting is Visibility and Graphics Overrides
Yours may be checked
Yeah, i tried that option but it's already unticked before i even could untick that option
May I see what you are referring to? A picture is worth a thousand words.
This is the original IFC file i've trying to work on in revit
@Anonymous: Here's first draft. I can't work with little more tomorrow for you. It's getting late here. Give me some feedback.
