Hello everyone ,
So i have been working on a project in revit 2024 but i want to open it in an older version of revit . I exported the file in IFC format but the thing is when i open it in revit 2022 the properties of my walls , furnitures etc doesn't appear . Please check the image below .
wall properties
IFC is an ouput file. So opening it in an older version of Revit will not turn it (fully) back into Revit elements.
So it is norrmally only used as underlay/reference. Do not expect to be able to use it for modelling.
If you want to see more parameters then you should look at your IFC export settings.
Look at the property sets tab on your IFC export settings
For example you can try to check "Export Revit Property Sets"
Louis
Please mention Revit version, especially when uploading Revit files.
