When i try and export an IFC from Revit 2017, nothing happens at all, so i have the 3D Window open. I click > Export > IFC > Choose my settings and location> Then click export. Then i get nothing, nothing at all happens. Can someone help, what am i doing wrong?
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Hi @Anonymous
I see that you are a new member! Welcome to the Autodesk community!![]()
Can you confirm if you have the latest updates for Revit 2017?
Let me know if the installing the updates resolve your issue, or I'd be happy to test your file.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
