IFC export problem
1 ANTWORT 1
Nachricht 1 von 2
panasevich999
180 Aufrufe, 1 Antwort
IFC export problem
I have installed Revit 2020. I need to export my model to IFC, but when I press - “export to IFC”, the window with properties didn’t showing. Revit just turned off. It also doesn’t work at new clean revit file
1 ANTWORT 1
Nachricht 2 von 2
Rafal.Gaweda
als Antwort auf: panasevich999
Hi @panasevich999
Please check
1. Make sure GBIS IFC Exporter from Solar Computer is not installed on computer.
2. Make sure Enscape is not installed on computer.
3. Uninstall all Autodesk \ GitHub IFC Exporters https://github.com/Autodesk/revit-ifc/releases
4. Install or uninstall IFC 2020 https://apps.autodesk.com/RVT/en/Detail/Index?id=8986482933300179260&appLang=en&os=Win64
5. Check Revit
If above did not help:
6. Update Your Revit with the latest available update if not updated yet
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-tie...
7. Clean windows temp folder
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-delete-temporary-...
8. Clean Revit journal files folder
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Location...
9. Disable ALL addins
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-Dis...
10. Check Revit
Rafal Gaweda
