I am having an issue with the IFC exporter (latest version) for Revit 2017. When exporting I select an MVD based on IFC2x3 COBie 2.4 Design Deliverable. After exporting Name in the Identification tab for the object concatenates the Type mark and Mark. It does not matter if I have a User Defined Parameter Set or Mapping file selected, it still does the same. I have tried exporting from other versions of Revit and the results are the same.
The other MVDs are fine, the Name is made up of the Family, Type, TypeMark, Mark. I have also reinstalled the old Revit Plugin and used the IFC2x3 Extended FM Handover View and the name was fine. Another issue is that the Description value is missing for all objects.
I am using a number of different IFC viewers to review the file.
Has anyone experienced the same or could someone suggest a way of using the mapping file to resolve the issue.
thanks
richard
