I want to kick this message off by saying its really encouraging to see the continuing improvements that Autodesk are making to the IFC export process. Still a way to go but it is good to see.
Having the IFC Export Mapping Dialog as part of Revit 2023 is a real step in the right direction. What i would like to have added to this is the ability to select a default schema in the dialog I.E the ability to select IFC 2x3 as a project standard rather than having to select this option each time for each family type in the project. Its unlikely you will want to select multiple different IFC schemas within a project so having the ability to choose a default would save time when searching the IFC Export Mapping Dialog.
Mark
And to expand on this it would be useful to be able to select multiple families and apply the IFC Export As to multiple deferent families in one go using the IFC Export Mapping Dialog in one go. This would speed up the process.
