Ifc export - glass in window
5 ANTWORTEN 5
Nachricht 1 von 6
heiminge
442 Aufrufe, 5 Antworten
Hello
In my project i've got windows made of curtain walls.
For the windows and doors we've made use of curtain panels. Inside this panel there is a family inserted for the glass.
When I export this I see the window as shown in the attachment
As you can see in the IFC viewer (BimCollab and Solibri) the element isn't shown as one element (glass is separate)
How can i also make the glass part of the element shown in a viewer?
By the way both the window and family are exported to the same category
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: heiminge
How about making the Glazing a Shared Family nested into the CW Panel Family?  Does that give you the output you want?
Nachricht 3 von 6
heiminge
Hello
The glazing is already shared and nested into the CW Panel family.
Thanks for the reply
Nachricht 4 von 6
Okay. So what is exactly that you're after?  Maybe I'm mis-readng you.
Nachricht 5 von 6
heiminge
In the IFC reader I would like the window to be exported as a single "Window" unit (so including the glass)
Nachricht 6 von 6
@heiminge wrote:
Hello
That is your problem.  Shared families are exported as separate elements.  Your curtain wall window family should not have any shared components nested in if you want them to be exported as single entities.
