I am trying to export IFC from revit file but always getting Empty IFC .Here i am attaching revit file , could you please advise what is the reason and how can i export . This issue only with this file all other files are working fine
Jose George
Architectural BIM/CAD Technician
josemukalel@gmail.com
+64 22513 0828
A KUDO is always welcomed; However, WHEN the above answer helps and/or clarifies your query; kindly mark it with ACCEPT AS SOLUTION
