IFC EXPORT APPEARS IN DIFFERENT COLOUR
1 ANTWORT 1
Nachricht 1 von 2
1267 Aufrufe, 1 Antwort
Hi Everyone,
I have problem while exporting IFC format. The elements marked on the photo below are supposed to be black, but some of them appear white in IFC format. I have been trying to use all kind of IFC export settings, but it doesn't work. I am using 2016 Revit version on Win 10.  I have also try IFC export in 2019 Revit version but it doesn't work.
The elements are Metric Generic Model Adaptive family. All elements from this family appears to have a same problem.Does anyone have a solution or idea how it could be solved?
Attached Revit file. IFC EXPORT REVIT FILE
IFC EXPORTIFC EXPORTREVIT FILEREVIT FILE
Tags (2)
1 ANTWORT 1
Nachricht 2 von 2
Aryen_Jacobs
als Antwort auf: Anonymous
You could try this version of the exporter:
https://github.com/Autodesk/revit-ifc
But if its important how your export looks IFC is not the way to go. All the geometry and information are usually correct in IFC but from experience materials and colors are very unreliable in IFC. Opening the same IFC in different programs might even give different colors.
