IF yes/no Parameter - How to use it?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
gpktm
1274 Aufrufe, 3 Antworten
Hi all
I have a plate where I want the pre-drilled holes to be visible by using the yes/no parameter. In order to do that I thought I should create an extrusion void and control the extrusion height based on the yes/no parameter. When type the IF formula, I'm getting an error message saying "Improper use of boolean expressions"
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: gpktm
if (Predrilled Holes, 15, 5)
Nachricht 3 von 4
gpktm
als Antwort auf: ToanDN
OK. So let me understand. The IF yes/no does not require a value, it automatically considers the yes/no as a "yes". Is that correct?
Nachricht 4 von 4
Alfredo_Medina
@gpktm
Correct. In plain English it would be: "If Predrilled Holes is true, set Thickness to 15, otherwise set Thickness to 5".
